Ga door naar hoofdinhoud
How to fix my power windows when they do not go up or down
My power windows don't work and when they do it always blow a fuse
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
This question was migrated from https://meta.ifixit.com/Answers.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Repairing power windows that are blowing fuses will usually mean a ad wire in the door jam . I would start there and look for cracked or bared wires. Check the wires continuity by finding each wire on either side of the door jam and testing each wire to see if one is bad . If this brings no Joy then move to the switches in the doors testing each of them . You can also test the winding motors in the doors could be a bad ground . Hope this is helpful
Was dit antwoord nuttig?
Score 2
There is probably a short circuit somewhere along the line. Remove the motorized parts and look for burn marks or exposed metal.
Score 1
Voeg je antwoord toe
Anthony Lockett zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 20
