Ga door naar hoofdinhoud
Reparatie- en ondersteuningshandleidingen voor wasdrogers.
870 Vragen Bekijk alle
Old Kenmore Elite Sensor Smart dryer (110.63062100) doesn't turn on
Control board (replaced 4 years ago) doesn't light up. Unplugging and replugging the machine worked a couple of times. Now I have to trip the circuit breaker, wait a few minutes, and turn it back. Then the dryer usually works, although not necessarily on every setting. Last time, knit/low heat wouldn't turn on, but air/no heat setting worked. After the machine started running, I turned it off and quickly pressed knit/delicate. Then it worked. Usually, once I get it going, it will keep working for a number of loads, especially if I do them in rapid succession. Occasionally, it quits in mid-cycle. What is going on? It wouldn't be worthwhile to put a lot of money into fixing such an old machine, but if there's an easy fix, I'd love to know about it.
Update:
I pressed on the part that fits into a slot inside the door, and the light in the dryer did not go off. Does that indicate what part needs to be replaced?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
I’d give the control board a good going over repairing cold solder joints, tighten up contact screws and test it out with a multimeter.
https://www.quora.com/What-is-a-dry-or-c...
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Judith Schwartz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 72
