Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
987 Vragen Bekijk alle
Error code 4013 during restore
I have an iPhone 7 that starts up directly to the restore screen. It is a model 1660. Its not bent or severely damaged. Every time I restore it, it gets to the Apple logo and bar screen then goes back to the restore screen and gives the error on itunes. I've tried restoring on windows and mac and used multiple cables. I have also tried using 3uTools but it doesn't restore through there either. Any idea how to fix this?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
1 Antwoord
Gekozen oplossing
You may have a device that was affected. See article from Apple
It starts off as a No Service issue. Before resetting the device check for Firmware Modem (in settings, general, about) if it exists, if not do not reset the device or it loops.
As for work-around, it's board related, so someone will have to check that defective component and replace it more-or-less.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
CAB zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 12
Altijd: 233
