Ga door naar hoofdinhoud
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Vragen Bekijk alle
Replaced battery on MBA won't turn on
Old battery was running low after too many cycles and temperature extremes. Replaced it and the mac won't turn on.
  • SMC reset done
  • Charging LED stays orange
  • Removed battery, LED stays orange, won't start
  • Removed SSD, with or without battery, won't start
Any idea? Should I say it goodbye?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Try making sure the battery cable is plugged in.
Also, the SSD should have nothing to do with it.
check to see if the battery is faulty.
Was dit antwoord nuttig?
Voeg je antwoord toe
Sébastien zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 45
