Broken control key after heat sink replacement
Today, I replaced the heat sink on my 13 inch mid 2012 MacBook Pro. I had some difficulty getting the keyboard cable in, but in the end I got it all the way. The keyboard worked, or so I thought. Every single key works except the control key. The key seems fine - you can press it like any other key, but nothing happens when you press it. Could I have damaged the cable? I bent it a little bit but it doesn't look broken at all.
Is dit een goede vraag?
