Released on September 19, 2014, this 5.5" screen iPhone is the larger version of the iPhone 6.
1360 Vragen Bekijk alle
iPhone 6 Plus screen is responding incorrectly
My iPhone 6 Plus does not correctly respond to my touch. For example, I would click on the U key on the keyboard and the Y key would be clicked instead. Also, I would be watching a youtube video and the screen would go crazy and rewind the video as if I was double tapping on the video to rewind 15 seconds. But I'm not clicking on the screen at all. I do not know anything about how to fix iPhone screens at all. I just want to know the possible causes. I am hoping I will be able to have this problem fixed if I brought it in to a shop or if I am able to fix it myself. Also if its any constellation, I bought the phone second hand from someone and so could it be possible that they had the screen replaced because it was cracked and the person who fixed it did not install it correctly? Thanks in advance :)
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
I have the same issue, had it a few months ago and when i woke up it was like it never happened but started again last night. everybody references screen ghosting. Cause by a couple of things supposedly, 1 is a cheap replacement screen, 2 dirty between screen and case or 3 broken solder connections.
As my screen is the original one, i fear replacing the screen wont fix the problem
IPhone 6S
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
1 Antwoord
Gekozen oplossing
You probably have a defective screen and that is certainly the first thing to try, whether you try and replace it yourself or have it done by a shop. If a replacement screen doesn't solve the problem, then you may have a logic board issue.
The iPhone 6 Plus does suffer from Touch Disease however the typical symptoms are more lack of touch or grey bars at the top of the screen.
So I would start by replacing the screen and if that doesn't solve your problem, you will need to consider a micro-soldering repair.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Paige S zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 40
