Ga door naar hoofdinhoud
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
384 Vragen Bekijk alle
Trying to make a custom ps4 case
Ive seen a few videos on youtube of custom ps4 cases. I don't really wanna take apart my ps4 pro, and im not wanting to go out and spend a few hundred on a new or used pro. I saw that ifixit sells the motherboard >>>> PlayStation 4 Pro (CUH-70xx) Motherboard <<<<
and was wondering if that would work, and if it did work what other important thing would I need to make it work like a ps4
Thanks so much!!
PlayStation 4 Pro (CUH-70xx) Motherboard Afbeelding
Product
$199.99
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sure, that would work. You'd also need the disc drive, power supply, hard drive, heat sink and fan. These components are made to fit perfectly inside the PS4 case and there is basically no room to move them or rearrange them. If you had some custom ribbon cables and other cables made you could to that but it would be difficult. Custom cases for these are very hard to make because PS4's are made to fit perfectly together with no room for moving anything.
Hope this helps.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Caleb P. zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 2,140
