Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
logic board are getting hot and new screen not working
was fixing my iPhone 6 housing, battery and screen. because it was broken. and after I install it all. the logic board are getting really hot when I turn it on and the screen does not work ( I have tried the screen on another iPhone and it works fine)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If the logic board is uncomfortably hot, then there may be a short circuit somewhere. Double check your work and check the connectors and flexes for any sign of damage.
If you connect the phone to iTunes enabled computer, does it get recognized? That would be an indication that the device is booting but the issue is with the display. Then check to see if the backlight is on. Bring the phone in a dim or dark room or look at the edge of the screen. If the backlight is not working, then shine a bright light on the screen to see if you have a dim image.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
door
I have double checked my work. it seems fine.
and I have tried to connect it to Itunes via computer and it said that "iTunes has found an iPhone that is for recovery. You need to restore iphone before you can use it with iTunes"
I can't see any light from the screen or the backlight
door
Voeg je antwoord toe
ricki_nguyen7 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 82
