no spark firing opel kaddet
Hi,
I ve got a 200is kaddet with an import engine code XEV. The car has no spark at all, the following has been changed so far: Crankshaft position sensor, fuel pum relay, ignition coil.
What can cause a no spark condition in these cars? car is doing 300 000km on the clock.
Is dit een goede vraag?
6 opmerkingen
Phelele Mazibuko can you let us know again what year your Opel Kadett is and possibly what engine size? What have you checked so far?
door oldturkey03
Its a 1998 year model, 2litre engine. Distributor less engine.
Changed the following:
Crankshaft sensor, fuel pump relay, ignition coil + leads.
door Phelele Mazibuko
You changed those parts because it did not have spark? It still has no spark so none of that made a difference? Ty to scan the ECU and see if you get any codes?
door oldturkey03
Will have it scanned on this comming weekend and let you know the codes.
Can a bad/failed engine knock sensor cause a no spark condition?
any help cz i have the same prob with my 1996 opel astra 1.6ie ... no spark
door Lebogang Lesokwane
1 commentaar meer tonen
