Ga door naar hoofdinhoud
GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
43 Vragen Bekijk alle
Can I order LCD ribbon cable ZIF con
I was trying to replace screen and did not do enough research before I started. Thought it to be no big deal because i replaced my iphone screen so easy. I was wrong. When removing the LCD ribbon cable I broke the socket it fits into, now I feel I'm screwed. What makes me even more stupid is I didn't backup first! Is there a way to replace this part? I have a picture if that helps you vision what i destroyed. Appreciate any help. Thanks
Is dit een goede vraag?
1 Opmerking
@missnotfix to post a picture with your question use this guide Voeg afbeeldingen toe aan een bestaande vraag
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
A picture would certainly help but if what I understood from your description is correct, a broken lcd connector on the logic board side, the iPad seems to be in trouble indeed. Replacement requires micro soldering skills and it's not very easy since a lot of pins hide behind delicate plastic. But please post a pic so that we'll be able to share what you see.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
will do, first thing in the morning. Thx
door
Voeg je antwoord toe
Traci zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 55
