Power Surge, compressor only runs after plugging in- help me diagnose
Have a GE side by side model GSL25JFTABS
Last night we had bad weather knocked out some of my electrical devices and my fridge. power surge most likely. Unplugged and plugged back in but the control panel would scroll 0's and not respond to any commands.
Took the fridge main control panel off and re-seated when I plugged back in the compressor came on and the panel now worked, but within a couple seconds the compressor turns off and the fan motor continues to run. The water will not dispense either so I'm wondering if something got blown that controls both the compressor and the water?
I was going to replace the main board but not sure that's the issue. Anyone have any ideas or had the same issue?
- when plugged in compressor runs but then stops within 10 seconds
- water will not dispense when the water lever is pressed
- all other controls on the control panel seems to be working
Thanks in advance
Is dit een goede vraag?
