Mac address change after logic board swap = wifi connection issue
Hi,
I'm having problems with wifi connectivity. Recently i've swapped out the logic board which seemed to work fine, I reset SMC and NVRAM to bring it back to speed (it had slowed considerably after the swap, but a reset of the NVRAM fixed this issue) but now have run into a problem I don't know how to take any further: with the swap the serial number as well as the mac address have changed, but the problem is that in my home network I cannot connect to the wifi any longer. I do not have problems connecting to a new wifi network, but it seems the mac address change is causing issues with known networks. So far i've tried only my home network as a known network.
Now, I've deleted all login info for the network and rejoined it a few times now but no joy. I'm thinking there is a possible conflict with the old mac address. But why would there be? The router is not set filtering mac addresses, nor should the ISP be. I read about changing the mac address manually, i guess i could give this a try, but it would only make sense with the old number...wich i don't know where to find anymore.
Hm. Any thoughts welcome. Thanks
Update (06/23/2018)
OK, so, replacement board is in, all working fine... except the WiFi connection at home. I'm a little bit stumped on how to proceed. Wifi DOES work at other location. What I've tried so far is:
On the Mac:
- Created new Location
- Deleted wifi home connection in the network settings and keychains
- Cleared out SystemConfiguration files / rebooted
- * updated to latest OS High Sierra (was not working in previous Sierra after board swap, still not working)
- Renewed leases on every step
On the router:
- Changed SSID & Password
- Set no password
- Changed DHCP number (because i can)
- Different devices connect fine to the same router (iphones & macbook)
- Can not change wifi channel its a 2,4 GHZ model only / its a provider branded router with minimal configuration options (o2 6341 - germany)
When trying to connect i get two types of messages:
- WiFi requires WPA2 password / invalid password (password IS correct / also changed it as a test)
- Something like move closer to router (I'm sitting right next to it)
So, all told, I don't know what else to try. My hunch is it has to do with the changed board (mac address) as it occured at the same time, which might be a coincidence, but then it might not. I guess the next thing I could try, do a complete new install without a restore and test it that way.
Any other suggestions would be most welcome.
Thanks!
Update (06/08/2018)
Meanwhile, after a re-install of the os and some more fiddling (adding these proxy settings *.local, 169.254/16) and AGAIN editing 'locations' today i had some connectivity to the home router but it would drop continuously and re-assign itself. Pings would take a very long time and browsing the internet was not possible due to dropping connection.
Where can i go from here?
Not having much luck so far. What is odd i think is that my mac address only has numbers, no letters. Could that make the router reject the connection? Hmm. I've reset the router, no joy.
Is dit een goede vraag?
The MAC address is a Hex decimal number which use the numbers 0 ~ 9 & the letters A, B, C, D & F. While rare it is still quite possible to get a board which is numbers only. Here's a listing of assigned vendor addresses Apple uses: Apple assigned Vendor Addresses. As you can see looking at the list alone Apple has made quite a lot of systems!
Here's a breakout of the numeric only Apple Vender ID's:
002241, 002500, 002608, 003065, 000393, 041552, 042665, 045453, 000502, 006171, 008865, 080007, 086698, 087402, 087045, 182032, 183451, 186590, 18F643, 283737, 341298, 403004, 440010, 503237, 600308, 606944, 609217, 680927, 701124, 705681, 748114, 804971, 842999, 843835, 844167, 848506, 885395, 907240 & 949426
Now you would add to this the burnt in address (BIA) which is unique to each system it to would be 6 Hex Decimal digits in length.
So your MAC address would need to be using one of these Vender ID's and a numbers only for your BIA.
door Dan
Thanks Dan, thats interesting info. My board has one of the numbers listed. So, that's good then. Moving on to next possible cause.
door Markus
@cito - review my update in my answer below.
door Dan
