Ga door naar hoofdinhoud
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 Vragen Bekijk alle
My charger cable is turning yellow after battery repair
Hi,
I have just changed my battery and everything when amazing but, I have noticed over the past month and a bit that my charger has turned yellow near the connector. Everything is functioning fine. The connector when charging gets very hot within 10 min of charging.
Thanks in advance,
Liam
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
That is a symptom of overheating and the cable should be replaced. You can read more here.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
The yellow color is indicative of oxidation, i.e. it is doing a slow burn. Please post a Coconut Battery image with the mag-safe connected.
door
I wonder if there is another problem.  If the problem didn’t start till you replaced the battery, then it could be related to the battery.  Is it possible that the battery is drawing too much current?  That could explain the “slow burn” that is now occurring.  Is the new battery an Apple battery, or is it an “after-market” battery?  If it is after-market, then it could be a defective battery.
Score 1
1 Opmerking:
Hey, I got my battery replaced as well and this only started happening after for me as well
door
Voeg je antwoord toe
liam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,900
