Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Repair and disassembly guides for desktops manufactured by Acer.
50 Vragen Bekijk alle
Windows 7 reset password/log in
I forgot the Windows 7 log in password to my Aspire AM3900G. How do I override it with out the reset disk?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
3 Antwoorden
Use laze soft password recovery, this tool won't give you your old password, however, it will completely remove the password, allowing you to create another one. All you need is a USB flash drive with the software installed, then boot up off of the USB from the boot menu on your computer.
Download
Was dit antwoord nuttig?
you can reset Windows 7 password with '''++Chntpw++'''.
It will be a little complicated. And also, you can use the professional tool like iSunshare Windows Password Genius. It can help you to create a recovery disk on any other accessible computer . Then you can reset Windows 7 password easily. But it will not help you find back the previous password.
Hello,
Firstly, you can try to boot Windows 7 in Safe Mode. When the login screen appears, if there is an administrator account is displayed beside your admin account, click it to sign in without password. So you can reset any other user account password in control panel after logging. Steps can be found here: Reset Acer Latop Password Windows 7 in Safe Mode.
If you cannot log on Windows 7 via Safe Mode, you can use a Windows 7 install disk to copy cmd.exe and rename it to sethc.exe, then open it from Windows 7 login screen. So you can reset Windows 7 password by using command line.
Voeg je antwoord toe
Andy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 154
