Ga door naar hoofdinhoud
Launched on November 2014, the HP Stream 13 is a thin unibody Windows® laptop priced to compete with Chromebooks and the entry level MacBook Air.
12 Vragen Bekijk alle
I am LOCKED OUT of my own laptop. How do I get in?
i HAVE a HP STREAM laptop with Intel. I am locked out. How do I get access to a backdoor so I can get back in?
Is dit een goede vraag?
1 Opmerking
There are multiple forms of being locked out of this particular system. Are you being challenged by a BIOS based code or a Windows system credential lock out? The procedures to proceed from each situation are different.
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
You'll need a bootable windows repair drive then follow this video
https://www.youtube.com/watch?v=4aNs0VdH...
Works great
Hope this helps
Was dit antwoord nuttig?
Score 2
You can use a start boot cd, search for OPHCRACK, it can remove your password or decrypt it.
Or you can try Hirens Boot, there is a loot of tools to remove passwords
I had a similar problem, the only way I was able to solve this was to use Lazesoft password recovery to reset the password. All you need is another computer and a USB flash drive; If the free version doesn't work try installing the free trial.
http://www.lazesoft.com/download.html
Voeg je antwoord toe
strongsilentype2000 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 4,935
