Battery Not Recognised - Led Battery Indicator with only one led
Hello,
A few days ago I managed to drop some water on the left side of my Macbook, it entered the USB / DisplayPort etc... It turned itself off immediately, I unplugged it from the charger turned it on it's left side to let the water out and it stayed like that for about 5 hours.
Later I took off the bottom cover, there was some moisture near the Battery connector but no major damage or corrosion anywhere. I cleaned everything I could and tried powering it on.
Laptop is working as it was before, the ports work but only powers on using the charger. Battery isn't detected at all, tried PRAM and SMC reset multiple times but no luck.
Battery was in good condition before showing 87% Health even after 1000 cycles. Weird thing is, the battery indicator on the side of the macbook has an led stuck on since then although the button doesn't work...
Coconut battery and System Info both say battery not available and Istat Pro too although this one also states my battery is charged.
Thanks in advance
Is dit een goede vraag?
