It won`t charge but It can only use Battery power.
I need help with my UPS. It won`t charge the battery that I replaced but It can use battery power. I replaced the battery that came with the ups (because its defective) and the replacement battery is charged. I replaced the battery with the same specifications (same amps and volts. no slight difference. EXACT). I used the replacement battery and it works fine. After Im done using it. I tried to charge it for 8 hours. Then I use it again. It won`t start and gives slightly-long beeps which means its low. Connectors are brand new and tested with other appliances. Fuses are tested with multimeter (Board fuse 2x 30 amps and fuses at the AC input female). I checked continuity of the wires and all of them are in good shape. Can anyone help me? You can tell me what to do with the board (I have knowledge about electrical and experience in soldering, etc). Do I need to change something like a capacitor or a mosfet in the board? I can send a picture of the board itself ASAP right when you asked for it.
Brand: Powercom Black Knight Pro
Model: BNT-650A / 650A
Board Model: BNT V3.0
Battery: CS3 GP 1272 F2 [12 volts 7.2Ah]
Battery is in good condition. Tested with another UPS.
Thanks in advance :)
[PS]
Diagram (Source: ElektroTanya):
(1) SCHEM1.pdf
(2) SCHEM2.pdf
Images (Source: Mine):
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(10)
Is dit een goede vraag?
Hi @ fbmt, it would be good if you can post more pictures,
How long is the UPS in operation?
If the UPS has been operating for some time, would suggest you also inspect the board for any "cold joint" solders
door Augustine
@salmonjapan I already added pictures. Kindly check. Thanks :D
door fbmt11
@fbmt11
That is helpful :)
Hopefully we are able to assist you to fix the issue.
door Augustine
I will say check where the AC passes to the board (input) and see if it will give you DC (output) from the battery connectors
door michael quartey
