Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Vragen Bekijk alle
in changing my battery, it caught on fire
After removing the burnt battery in my attempt to replace it, I since cleaned the phone, it turns on and I can do all things (as far as I know) except the actual "Turn ON" meaning when I press the power button, it does not turn on, I have to connect it with the power cable and wait till its fully up or it will turn off. Once its up, it stays up and I seem to be able to do all things, including waking it up with the power button and turning it off with the power button. Now I know I fried a few cables internally but I am at a loss as to what they are. Here is a link to those PICS
pics
Is dit een goede vraag?
1 Opmerking
Antenna seems to work fine, I et WIFI and LTE access and have tested them, my problem is powering up the phone.... I cannot do that unless I plug it in, battery is at 100% and the power button (once on) seems to be able to wake the phone up and power it off completely, BUT it will NOT power it up from a power down.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Take a look at the teardown, as far as I can see those areas you pointed out are the antenna and the side button keys. Since this phone has been out a while most likely the components are replacable, see parts.
Teardown Guide
Good luck friend
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Check this cable line that you acknowledge was damaged in the photos.
iPhone 7 Plus Audio Control Cable and Brackets
door
The left wifi antenna looks quite burnt
Voeg je antwoord toe
Safe Junk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 283
