Ga door naar hoofdinhoud
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
78 Vragen Bekijk alle
Tail lights, plate lights, and dash lights don't work.
I found the fuse box (under the steering column) and replaced the correct fuse. I turned the key to see if the lights were on - and they were!
BUT then they weren't. Stopped working within 30 to 40 seconds. What to try next?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Check your fuse again. It probably has blown again. If you find that the fuse has blown again, then you will know that there is an electrical short somewhere. Take it to a mechanic.
The good news is that your car is very standard; it can be repaired by pretty much all mechanics.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
That's kinda what I thought... I was hoping there might be "one more thing to try" before I surrendered. Thank you.
door
Voeg je antwoord toe
joanie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,744
