The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
489 Vragen Bekijk alle
White screen with some black border and lines?!
Hi,
I replaced screen and everything worked very well until I saw that Display is not tied great and it was loose. You can move whole display back and forward for like 0.5cm.. So I open my laptom and tied some screws. Everything was great until I turn on computer and display wont show. I attached everything as I should and it just stoped working.
I plug external monitor and everything is working fine.
So there is 100% something wrong with display. Hope that is LDSV cable.. :/
Ill attached a photo of screen. Its white with some vigneting black border and some black lines.
Here is photo:
https://ibb.co/i2a3Y8
Is this LDSV cable error or did I do something to my new screen? :S
Thanks for all replies!
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
1 Antwoord
Gekozen oplossing
LIFE_OF ROK double check your work. This "until I saw that Display is not tied great and it was loose. You can move whole display back and forward for like 0.5cm.. So I open my laptom and tied some screws" is what makes me wonder if there is something that went wrong with the installation. The best would be that you redo everything based on this guide MacBook Pro 13" Retina Display Early 2015 Display Assembly Replacement It is possible that it is your cable/connector but until you check, it is difficult to confirm. right now all you are getting is the backlight but no signal.
Was dit antwoord nuttig?
Commentaar:
Thanks for quick answer. I do like 10 times with this guide and its still the same.
:S Do you think that this could be display error or cable?
door
Check the cable for any damage on the connector. If it does look okay then it could be the display.
door
Voeg je antwoord toe
LIFE_OF ROK zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 50
