Ga door naar hoofdinhoud
Bluetooth on-ear headphones with 40 mm drivers and a 610 mAh battery. Released in 2014.
21 Vragen Bekijk alle
Pinout charging cable JBL Synchros E40BT
I lost the charging cable of my JLB Synchros E40BT headphone and was thinking about to make one myself. I just wondered what the pinout was.
Is this the same as for the iPod Shuffle?
usb cable to head phone jack .Is it possiable to make work
From the audio cable I figured out three connections, but I'm not certain for the 5V line. And I don't think the D+ and D- of the USB cable should be connected, right?
  • tip - audio left
  • ring 1 - audio right
  • ring 2 - ground
  • sleeve - 5V ???
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Hi, Cable are selling for e50bt too, so i assume they have the same pinout. In my E50BT is like this
in this order USB —> Cable —> Jack 1,2,3,4 Rings
1 = +5v
2= GND
Was dit antwoord nuttig?
Score 3
@noob99 that will depend on how it is setup on the inside of your headphones. It is very conceivable that the wiring is identical to the one you listed usb cable to head phone jack .Is it possiable to make work For the $2USD I would go ahead and buy a new one from places like this That way you know that the connections are right.
Score 1
How how can I charge it with out the headphone charger
Hello,
The original cable is available on https://ecommerce.mysav.eu/en/jbl/59-cab...
Regards,
Voeg je antwoord toe
Henry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 39
Altijd: 5,738
