Ga door naar hoofdinhoud
The Apple Extended Keyboard is a keyboard that was introduced in 1987 and first sold separately alongside the Macintosh II and SE.
4 Vragen Bekijk alle
Apple keyboard stopped working
Could cleaning the surface of the keys with mild soap and water on my Apple A1243 keyboard make it quit functioning?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
The simple answer is YES!
Most people don't realize soapy water is corrosive! So while it might appear to clean things up any leakage into the switch elements can kill them.
Always wet the cloth so its just damp and then use it to wipe the body and keys. As far as what cleaner to use it gets down to what you need to clean. Windex window cleaner and Isopropyl alcohol are a good starter.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Basic Drill From Apple
Apple products are made with a variety of materials, and each product might have specific cleaning requirements which vary by the part you're cleaning. To get started, here are some tips that apply to all products:
Use only a soft, lint-free cloth. Avoid abrasive cloths, towels, paper towels, and similar items that might cause damage.
  • Unplug all external power sources, devices, and cables.
  • Keep liquids away from the product.
  • Don't get moisture into any openings.
  • Don't use aerosol sprays, solvents, or abrasives.
  • Don't spray cleaners directly onto the item.
Score 1
Voeg je antwoord toe
wolfroger zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 505
