What is the deal with the specificity of the HDD this rig will accept
So I just had my CPU card fixed, and installed it, along with another HDD. The one it came with was a Seagate ST31000528AS 9SL154-040 .
I know that there is discussion about compatibility of HDDs in this machine, but do not fully understand it.
After some reading up I concluded that it came down to the temp sensor connector being very specific on the A1311. Since I could not find the exact same Seagate, I tried a fully operational Hitachi Deskstar 7K100 1TB 7200 rpm Internal SATA 3.5 Hard Drive HDS721010KLA330, which I still had in my box of parts.
I dealt with the temp sensor by shorting it, to prevent it from spinning full tilt, and then installed Mac fan control and set the HDD to 2500rpm.
I fresh install of OS 10.6.8 on the new drive and all was well.
Next day, for reason beyond my comprehension, it suddenly does not recognize the HDD!! WTF?
My question is : What makes the EMC2308 so HDD fussy? Is there some firmware interfering with my choice of HDD?
Any light on the issue would be, as usual, eternally appreciated....Cheers, J
Is dit een goede vraag?
3 opmerkingen
OK, after following your links I have got it. I do need the sensor upgrade kit so the logic board can communicate with the HDD and understand its language. Thank you so much, Dan. You, as usually, rock.
door Jurgen
@danj , I am not sure what you mean with your comment: " You may need to replace the PRAM battery as the Startup Drive setting might be getting lost." Would you please inform me about the relationship of the battery and the PRAM. I am foggy on this, to say the least...
door Jurgen
The PRAM (NVRAM) holds settings like what disk is the boot drive as well as the date & time. The PRAM battery gives the PRAM the needed power to hold this info when power is lost (vampire voltage).
Here's the IFIXIT guide to get to it: iMac Intel 21.5" EMC 2308 PRAM Battery Replacement
door Dan
