The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
237 Vragen Bekijk alle
Will ipad charge without digitizer and LCD connected to it?
Checking to see if battery is bad so easiest to do it this way if it will charge. Battery was at 0.01 v so wondering if charging chip was bad or if fellow didn’t tell me all of what happened ?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
1 Antwoord
Gekozen oplossing
The iPad should charge the battery even though the LCD/Digi are not installed. You can use programs like 3uTools or coconutBattery to keep track of the charging state (the device has to be trusted first and not have a PIN).
A battery at 0.01V is not good though...it should never be depleted down to that level.
Was dit antwoord nuttig?
Score 1
Commentaar:
Hope it would change... not yet warming up either battery or charger. I guess i could check under terminals. Thanks for your help.
door
Hey guys, just found out it will charge without LCD and digitizer connected but not if power button is not connected. Found by accident once it was snapped in then charger started getting hot.
door
Voeg je antwoord toe
Perry Green zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 31
