Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
Why does my service not work after repairing the charging port?
I replaced my charging port on my 7 plus step by step and now it is correctly charging but has no service. Wi-fi works. What antennae is not functioning correctly and what do I need to replace/ where did I go wrong?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Check thee two antenna cables (Step 39) in this guide. Also double check that the proper screws are in place as the LTE antennas are embedded in the housing and the screws a make all the proper connections.
Was dit antwoord nuttig?
Score 5
3 opmerkingen:
Do the two antenna cables both function for the LTE or is one wifi? If damaged, would I get another charging port and then antenna for the speaker?
door
The WiFi antennas are at the top of the housing. Check the cables first, they migh simply be incorrectly connected. If they are damaged, then replace as necessary.
door
Are the two coaxial cables in step 39 interchangeable or is one of the specific to a charger port replacement?
door
Voeg je antwoord toe
Knox Watson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 4,077
