My sound system not working
please my sound system just stoped working and the sund driver seems to to be ok what can i do to get the sound back on
Is dit een goede vraag?
There are a lot of different things that can cause this type of issue. In order to give more guidance, we may need more information. Such as:
Windows version (7, 8, 10)
Current Build version (1709, 1803, etc...)
Computer make and model
The most recent causes of these issues, from what I've been experiencing, is the Windows 10 1803 update. This has been affecting both manufactured and custom built computers (desktops and laptops) with 5th generation and prior Intel processors or AMD APUs.
The manufacturer may have released new drivers for the computer to fix the issues, but it may be necessary to revert back to a previous build version.
Was dit antwoord nuttig?
No sound what do I do
i allso have the some problem but am using windows 7
and at times when ever i restart it sound jumps off .What should i do?
Hiya!
So I just had a similar problem, and it was SO frustrating! But, assuming you are on Windows 10,
Go to settings and type in sound.
Click on “sound”
Right click your default sound system in Playback, and click disable.
Then, after at least 5 seconds, right click it again and click enable. Then test your sound.
I hope it works for you!
I tried that and it didn't work I still have no sound
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 5,489
3 opmerkingen
Hey bud, I assume you are running windows? Have you checked to see where windows is sending the sound? I e built in speakers, through external speakers, Bluetooth, another monitor etc. Has something recently changed? Hardware/software?
door Lee Opie
I have the same issue in Windows 7. Says "No Audio Output Device is installed". But when I check devices, it says everything is up to date and working properly. I have red x over my speaker icon. I have tried disable/enable sequence. Updated drivers etc.
door Dan Faber
my sound on my acer spin 1 does not work
door bkpoirrier
