Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
iPhone fell down —-> Touch stoppen working
So i was using my iPhone, when it fell down and the glass broke and the touch dindt want to work anymore.
So i bought on amazon a lcd display and replaced everything ( battery disconnected all time ;) ) but its still not working.
Anyone been through this? Or knowing what the problem could be?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
It sounds like your phone now has "Touch Disease", it's a common failure on the iPhone 6 Plus.
If you are confident that your replacement screen is fully functional and there is no damage to the Digitizer FPC connectors on the logic board, then your phone probably suffers from Touch Disease. This is not a DIY repair. Look for a repair shop that can do micro-soldering repairs to properly diagnose your problem.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Thanks for your informative answer, appreciate it.
Do you think this can be fixes bu just heating up the touch IC with some flux and 350-370 degrees celsius for some seconds?
door
Check out the link I provided...it is usually caused by a broken trace so reflowing the IC will generally not work or at least, work for long.
door
Minho, i got 1 more question. If i reflow it will it work for at least 2-5 days?
And do you think that someone could do this on his own
I didnt ever have smd soldering or sth like that
But i had normal resistor capacitors soldered
door
Voeg je antwoord toe
Nenadbrateu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 109
