Battery replacement- Phone not turning on
Just replaced my battery
The phone is not turning on, though I can feel some heat while it is on charge.
My PC does recognize the device
Is dit een goede vraag?
You may have damaged the backlight circuit on the logic board if you disconnected the screen without disconnecting the battery first.
To be certain, shine a bright flashlight on the screen when you connect it to iTunes. If you see a dim image, then your backlight circuit is blown and will require a micro-soldering solution.
Was dit antwoord nuttig?
No, nothing happened
And when I tried connecting my phone, it recognises it at first and then says an unknown arror occured, which suggests that it is not the screen.
I may just replace the logic board and see what happens
When i place my hand on the circitry it is warm
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 66
2 opmerkingen
door DochMcCrum10
I just replaced my battery. It won't turn on. I plugged it in to charge and the apple lights up for 5 sec then goes off for five sec, repeating now. Any suggestions?
door Marilyn Newton
