Ga door naar hoofdinhoud
Screen not working after 1 month of use. (after screen replacement)
I have the following problem:
I've replaced an iPhone 7 with a OEM screen, Everything was working fine and customer was happy with the replacement.
After +/- 1 month of usage, the customer started complaining about touch not working correctly and also the screen was "doing things by itself" like switching screens etc.
So what i did:
I replaced the screen with another screen, but this time I used an Original (pulled) screen.
Also this time, customer happy and everything working perfectly. But after (again) 1 month the screen starts showing the same issues as mentioned above.
Any suggestions what to do?
Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Are you seating the ribbon cables correctly with the metal plate that goes behind the screen like it originally is placed? (e.g like it is when you open the phone for the first time)
Here is a link to how it is placed usually:
https://d3nevzfk7ii3be.cloudfront.net/ig...
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Yes, cables are placed as usually.
I've replaced multiple iPhone 7 by now but only this one is showing this defect.
Strange this is that it only pops up after a month....
door
Are the screens seating in properly? None of the corners of the screen pushing up?
door
Voeg je antwoord toe
Alex zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 74
