Ga door naar hoofdinhoud
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Vragen Bekijk alle
Install optical drive in external enclosure
Hello, my old MacBook Pro just died due to a logic board issue. It was already repaired once so I've moved on to a newer model. However, I am interested in removing the optical drive and placing it in an external enclosure, so that I can use it as an external disc drive. I've already done this with the hard drive from the old MacBook. My question is, will the OEM optical drive fit the enclosure linked below? My Google-fu is failing me when it comes to figuring out what optical drive is installed in this MacBook, and whether it will fit in this enclosure.
https://www.amazon.com/OWC-SuperSlim-Enc...
Thanks in advance!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
This is probably the drive you are working with:
Unibody (Post-Early 2009) 8x SATA SuperDrive
Unibody (Post-Early 2009) 8x SATA SuperDrive Afbeelding
Product
$44.99
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
Will it work in that enclosure though? OWC support advised me that the enclosure requires a 9.5mm drive..not sure what that means or if that drive is “9.5mm”
door
Yes, the OWC case will work for your removed optical drive so you can continue to use it.
door
This is what you will need -> https://catjuggling.com/fix-external-dvd...
Voeg je antwoord toe
zach.a.eye zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,160
