Released September 25, 2015. Model A1688/A1633. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
1759 Vragen Bekijk alle
water damage and no service
what may be the problem here i have cleaned the motherboard and the antenas with alcool but still no service sometimes the service comes and i can make calls but lasts just 2-3 mins and goes back to no service the imei is there in both places in settings and when i tybe *#06# the imei shows i have changed the charging port and the 4g antena but still the same
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Antwoord
Gekozen oplossing
How thorough was your cleanup procedure? Did you put the logic board through an ultrasonic cleaner?
Water damage boards are not all recoverable, some have damage that can simply not be repaired. If you are having issues with the RF portion, then check all of the input/output voltages for U_PMU_RF. If anything seems wrong, then follow that line to see where the problem originates. You may need to reball the BBCPU and possibly some of the other RF IC's.
Was dit antwoord nuttig?
Score 4
Voeg je antwoord toe
Adrian Zymeri zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 4
Altijd: 81
