Ga door naar hoofdinhoud
Third generation of the Integra, the last of which would be called "Integra" in North America.
DIODE blowing and don't know why
I have a 2000 Integra with b20 when I go to shift outta 1st gear into second, the car just dies, look under the hood and the EFI/EM 15 amp fuse keeps blowing, I would change it out and car will start right back up, but keeps blowing that same fuse, even tried going a lower amperage, checked ignition coil, spark plugs, don't know why
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
You dont want to try a lower amp , you would want to try a higher amp to be a little stronger , But dont do it , look around for a short , when your driving and changing gears you motor moves , it can be moving and touching a wire some where , you can reply if you dont see any wires , I will try to help you !
Was dit antwoord nuttig?
Voeg je antwoord toe
Damien zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 147
