Repair and disassembly guides for Brother printers.
189 Vragen Bekijk alle
No scan tab shows up when I add my MFC-8890DW to my mac
I'm using the latest MacOS trying to add a printer/scanner that is on a different subnet. I'm in the 10.0.1.x while the printer /scanner is in the 10.0.0.x subnet. When I try adding the printer by IP it adds correctly, but without the scanning tab (scanning functions). I tried to sue the control Center to configure the scanner, but after trying to add it, the left most side of the window stays blank, it does not says Network/USB in the next tab and the last tab just says online. This mac previously had it's scan functions before it was moved to a different subnet.
Any help would be greatly appreciated.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
Hi @danj ,
Would be interested in your thoughts on this problem.
Cheers.
door
Oh, brother! ;-}
Sorry, @jayeff - I don't have a clue why moving to a different subnet would cause the scanner part to disappear. I could see it going gray (in active).
What would happen if you move the Mac system to that subnet does it show up then? If it does then the issue would be the router may not allow the dialog between the Mac & Brother printer to be bi-directional between the subnets. Keep in mind the 10.x.x.x network is a non-routable network so unless the router is properly configured all connections go to the default gateway and out to the internet.
It's also possible the print driver needs an update or have issues when it can't poll the printer from the Mac (or the reverse Printer to the Mac) within the same net but different subnets.
door
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
1 Antwoord
Gekozen oplossing
Hi @cakebuns ,
Are you using the Brother MFC-8890DW printer drivers applicable to the OS or are the generic Mac drivers applicable to your printer model installed?
Was dit antwoord nuttig?
Score 2
Commentaar:
I am using the official Brother drivers.
door
Voeg je antwoord toe
James zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 14
Altijd: 214
