Roomba won't leave the dock
Hi, my Roomba 650 won't leave the dock anymore. It won't do it on schedule nor when I press the clean button. If I take it off the dock it will work perfectly and dock itself as well. I suspected a battery issue and changed the battery but this didn't help. I've also reset the Roomba a few times and moved the dock to different places.
I haven't seen anyone having this problem even after some serious searching. Any ideas?
Is dit een goede vraag?
8 opmerkingen
It must be scared of your cat ;-}
How old is the unit? You may need a fresh battery pack as it thinks the charge is not enough or the logic is damaged.
door Dan
I already changed the battery.
door Ville Veijalainen
I guess I just have to start the Roomba manually. There is hundred problems with hundred answers, but of cource I got a unique one. :)
I'm having the same issue. When I press the clean button, it leaves the dock for 5 mins or so then goes back to the dock. When I pick it off the dock and start it out in the room, it ran for about 15 mins.
door Chad Copsey
This is not the same. When I press the Clean-button while my Roomba is on the dock nothing happens. Out of the dock it works perfectly and cleans at least an hour. Your problem definitely sounds battery related.
3 commentaren meer tonen
