Ga door naar hoofdinhoud
7.9 inch display / Model A1455 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
30 Vragen Bekijk alle
My iPad mini still won’t turn on after battery replacement
I bought the battery and followed all of the instructions per the ifixit’s website and my iPad mini still is not working. What is my next step?
Is dit een goede vraag?
1 Opmerking
It was the same issue when I bought the new battery. My iPad all of a sudden stopped working. I did all that I could for it to turn it on. I tried all the resets .So I bought the new battery and still nothing.
Just off the suggestions you game number 2 would be it “If the iPad was not working before your repair attempt and you thought a new battery would revive it, then your iPad was probably suffering from something else”.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
What was the original problem that led you to buy a replacement battery? Was the iPad working before you attempted the repair?
Once you give us more details, we'll be able to help just remember that this site is not staffed with iFixit personnel but rather volunteers who help out fellow DIY fixers like yourself.
Here are a few ideas:
  1. If the iPad was working well before but the battery life was poor, then you either have a defective battery or something went wrong during the repair. If you have access to a multimeter, you could try to measure the voltage directly at the battery terminals. You need to have >3V for the device to boot. Leaving the battery on charge overnight may do the trick here. If you have access to a USB Ammeter, you could use that to determine if the device is really drawing current when it says it's charging.
  2. If the iPad was not working before your repair attempt and you thought a new battery would revive it, then your iPad was probably suffering from something else.
Let us know and we can help you further.
Was dit antwoord nuttig?
Score 3
It wouldn't turn on so I thought the battery was done
Voeg je antwoord toe
Tiffany Horton zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,424
