Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
No ring sound after changing charge port.
I recently changed a charge port to fix a issue with microphone.
However when I test ring the phone there is no sound. If I go into Sound settings, I can adjust the ringer volume up and down and sound does come out the loud speaker.
I have taken the phone apart numerous times and the ringer does occasionally work but when I close up again it generally stops working.
I have replaced the charge port 3 times ( same supplier though ) and I have replace the speaker. Occasionally it works but as soon as I close it stops working.
Could the mute button on the side somehow be turning on when I close the screen ??
Thx
Is dit een goede vraag?
Score 1
4 opmerkingen:
Any possibility it could be battery related in some way? Battery does seem fine but that is just general appearance and assumption.
door
Finally got it working although not entirely sure how. I tried fitting and OEM screen in place of original aftermarket and everything worked. Convinced this was the solution I put the original screen back as I wanted the get go ahead from customer before replacing screen and now everything works with original cheap screen.
I got no idea what just happen but will not open that %#*@ phone again LOL.
door
It's a weird grounding issue that I and other users on here havent figured out what's causing yet.
Currently I assume it's due to the quality of the replacement charging port.
door
its not a real reason
door
Voeg een opmerking toe
1 Antwoord
May be what I am saying is write answer or not but I too had the same problem but the only solution is put the charging completely until it completes 100%. I think the mobile while charging gets compatible with power supply and when we replace the socket it take some time to compatible with power,for example when the power supply is gone in home all components get closed or stop working ,suddenly when it comes back one by one started working (components),the low voltage bulb turns on first whether the high voltage on at last.In the same way our mobile components work similarly.
Was dit antwoord nuttig?
Voeg je antwoord toe
David zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 504
