Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen en ondersteuning voor een breed scala aan sieraden.
very hard setting, very clear epoxy glue
Hi all. Can anyone recommend an epoxy glue that I can repair a cracked and chipped agate stone that is set into an expensive ring. I really dont want to have to replace the stone as its an irregular shape so fitting a new stone to the ring will be too hard. I want to try to mask the cracks and missing spaces with a tough but clear glue that wont yellow with age. I anticipate mixing it with acetone to give it additional flow. I found something very expensive stuff but before i go that route Id appreciate seeing if anyone has any recommendations. Araldite was too opaque and yellows I think. Many thanks
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
had a look and can find this but not sure if its what your looking for or not https://www.amazon.com/Epoxy-330-Water-C...
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Thanks so much for looking. I'm in the uk and they dont ship to uk. will look and see if I can find it on the uk amazon
door Deel
what about car window chip epoxy
door Deel
good idea. I wonder if I can get it in small quantities though. Its the shipping that seems to send the cost up. I found the 303 glue but even on uk amazon the postage is 3 times the price of the glue! Thanks for your input
door Deel
door Deel
Hi I have great success with UV resin it uses ultraviolet light from a UV torch or even the sun, you can get it on Amazon, hope this helps.
Voeg je antwoord toe
Cecilia Leete zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 46
Altijd: 1,209
