The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3790 Vragen Bekijk alle
iPhone 5s Wifi Module (Wifi IC)
Hye I got an IPhone 5s sent in to me regarding No Power issue. After I probing around, the phone showing a low resistance on VCC_Main and have a short on the same line. After remove the Wifi IC, the short are completely gone and I think it solved the issue. Also the phone booted up normally (Without Wifi IC). But after a few minutes the phone suddenly turn into Blue Screen and reboot automatically.
When I was removing the Wifi IC some of the pads are gone 34,35,36,37,43 (The number is based on ZXW Tools).
So my question is..
1. Does this line is responsible for Blue Screen issue ?
2. Is it okay if I just put back the Wifi IC without making a short (Jumper) on the lost pads ?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
1 Antwoord
Gekozen oplossing
WLAN IC:
Line 34: BT_PCM_IN
Line 35: BT_PCM_SYNC
Line 36: WLAN_CLK32K
Line 37: BT_UART_RTS_L
Line 43: 50_WLAN_G_ANT
Unfortunately, all of those lines are important so you will have to add micro-jumpers to get them properly connected. If you are removing pads when desoldering, then you may be using insufficient heat. When the IC is not underfilled, check to see if it "floats" on the solder prior to removing it. For underfilled IC's, then you need to remove as much surrounding underfill as possible first and use something to rpy your way underneath. Some specialized tools are available for this.
Was dit antwoord nuttig?
Score 3
Commentaar:
Does the blue screen issue also because of those lines
door
I doubt the blue screen is caused by your WiFi issues. Check the screw standoffs to see if there is any possible Long Screw Damage.
door
Voeg je antwoord toe
Azim WHITE zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 9
Afgelopen 30 Dagen: 20
Altijd: 160
