New replacement battery not charging
Just replaced the battery with Item code: IF161-105-4
MagSafe charging cable is green, battery came with 62% charge. Down to 61% because I unplugged for a bit to test. I did PRAM and SMC resets.
Here is CoconutBattery info:
- Manufacturer: Simplo
- Manufacture Date: 2018-03-12
- Age: 39 days
- Load Cycles: 0
- Serial Number: D861015004NDGDL3T
- macOS battery Status: Good
- Temp: 27.1 C
- Battery failure: none
- Power Adapter: 85W
- Charging with: 0 W
- Power adapter: Connected
Is dit een goede vraag?
2 opmerkingen
@davidmatthew did this solve the problem?
door mayer
I am getting the same issue again.
door David
