Ga door naar hoofdinhoud
Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
Replaced Battery, Now My Phone is Overheating and Won't Boot
Hi,
I've had my OnePlus 3 for about 2 years now and it was overdue for a battery replacement, so I decided to replace it myself. I bought an OEM battery and carefully replaced the old battery with the new one. After doing this, I attempted to charge it and noticed it was getting very hot at the top of the phone, like dangerously hot. After I got it to boot up, It would reboot after a few minutes of use and remained very hot to the touch even after removing the dash charger. So I decided that the battery must be faulty and put my old one back in and thought I'd just get a refund for the new battery. Unfortunately, the issues I was having with the new battery have continued with the old one too, so now I can't even get the phone to boot or take a charge at all now, even after trying the unbrick tool. I get the low battery notification, then afterwards I get a vibration with nothing on the screen every 2 seconds while it's connected to the charger and it still heats up like mad at the top of the device. Does anyone know what I might be able to do to resolve this problem? Should I maybe try and replace the main motherboard or the Type-C port perhaps? I explained to my friend and he suggested I might have shorted a component due to static or something but I just don't know.
Thank you for any suggestions. :)
Is dit een goede vraag?
Score 2
4 opmerkingen
Hello, where did you source your OEM replacement battery? I ordered one from iFixit this past week but they told me today they are actually out of stock.
Please advise.
door
Hi,
I just experience exactly the same issue…
The overheating appears even in recovery mode, so it definitely related to hardware (anyway a full reset didn’t help)… :-/
I’m afraid something in the mobo has just “fried”. I don’t know whether I has something to see with ESD or a bad battery that could damage something, but I fixed many phones of various brands in the past and I never encounter such an issue.
Did you have found any solution to fix it?
door
Unfortunately I didn't, I ended up selling the phone for parts only on eBay. I'm not sure if the person who bought it found a solution or if he just used it for parts. I'll send him a message and see. :)
door
You probably need an IC reball
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Had the same problem with my Oneplus 3 and found the solution by myself. Its when you put the flat cable between subboard and mainboard not in the right direction. I have no idea why, but you are able to assemble it the other way round and then the Phone overheats. I found the problem very quick and since then my phone is good again.
Sorry it’s too late for you
Was dit antwoord nuttig?
Score 15
20 opmerkingen:
That's very odd that reversing the cable has that effect. I really wish I thought of that before I decided to sell it. Oh well, hopefully this will help anyone else having the same problem. Thank you for your reply! :)
door
Wow mate, you saved me!!! I had this same issue and was just about to pack it in and spend hundreds to get a new phone. You rock, thank you so so so so much!!!
door
You are my hero bro! Works. :-)
door
worked for me too. thank you!!
door
Dude... DUUUUUDEEEE. THANKS !!! You saved me 1000 times mate !!!!!
door
15 commentaren meer tonen
Voeg je antwoord toe
Joseph Gibson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 50
Altijd: 5,032
