Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
iPhone 5s stuck on red battery symbol.
Recently purchased an iPhone 5s.
Had it plugged into my Mac for about the last 40 minutes and it's showing the red battery on the screen.
When I unplug, it says to plug in the lightning cable.
I've opened the phone and unplugged the battery connector and plugged it back in.
Not sure if there are any solutions I can try, just desperate for it to work.
Thanks,
Sam <3
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Apparently, a battery replacement will fix this issue.
Is that correct?
Was dit antwoord nuttig?
1 Opmerking:
Not always, the issue could be caused by a few things, not trying to charge the phone via a wall charger instead of USB port from a computer.
A bad tristar charging chip, which requires board-level repair to fix that problem.
But it's always good to try a battery after you exhausted the basic troubleshooting steps like trying another charger and etc as it's cheap to try.
door
Voeg je antwoord toe
Sam Mileberg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 959
