Ga door naar hoofdinhoud
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Vragen Bekijk alle
How to properly clean dirty speaker grill the top one and the bottom s
When playing something using the phone volume, it’s low and barely hear them. Tried cleaning the top speaker grill with alcohol swabs it helps a little but don’t know how to clean the bottom speaker.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Properly cleaning the top and bottom, two methods.
Basic way, use a anti-static brush, some use a toothbrush but I always take the safe approach, and gently brush the grills. Do not dig the bristles into the grill, so use a swiping motion.
Deep Cleaning, open device, pull speaker and mic component out, use compressed air to blow from inside out, brush if needed.
Keep in mind that if you're going to open the device you need to be cautious with the gold contacts and electric static discharge on the device. Mishandling can lead to improper functioning of the device. Follow the examples on Ifixit for dissembling the unit.
Do note that Apple has some strict guidelines about "tempering" with the device. If something were to go wrong it may void out any warranty services.
Good Luck
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
BenSihte zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 17
Altijd: 3,935
