MacBook Pro has a bad backlight. How do I know which parts are broken?
My MacBook Pro’s backlight broke on the board the other day. However, I really don’t want to spend $200 for Apple to fix it and would rather just do it myself instead. Although, I’m afraid to say that I have very little to no experience with this stuff. I do not even know which fuses I need to replace in order to fix this problem. I also am not sure if I have the right resources for this. All I have is a $7 soldering iron (also, I can obviously buy the replacement fuses if I need to). Could just a soldering iron pull this off? Also, would anyone happen to know which chips and fuses are blown on the board or how I can find out which ones are broken? I have provided pictures of the board.
Based on only doing research with Louis Rossmann, I believe the backlight chip is where that “P” symbol is, right? That’s why i took a close up picture of that.
Is dit een goede vraag?
3 opmerkingen
I agree @oldturkey03 the LVDS connector looks like it got wet as it has some corrosion.
door Dan
Hi Cameroon,
After 2 years what was your solution?
Thanks
door Erick Lopez
@kimahrironso - I doubt Erick will respond as its been quite awhile.
If you have the exact same issue then you'll need to follow our answers below or find someone with the needed skills and tools to do it for you.
door Dan
