The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3850 Vragen Bekijk alle
iPhone 5s: No screen or vibration after battery replacement
I used the iFixit kit to replace the battery in my iPhone 5s, but now the screen is black and vibration seems to be broken. The phone is detected by iTunes when turned on, and I was able to put it into DFU mode to verify that the home button works, but that's all it can do now. I even tried disconnecting the new battery and connecting the old one, but nothing changed. I didn't remove the screen for the repair, because it seemed like more trouble than it was worth, but I did open it up a second time and tried de- and reattaching the LCD cable, with no effect.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
I just got a call that vibrated my phone, so I guess I knocked out the mute button (and possibly the volume control, based on another experiment), not the vibrator.
door
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
1 Antwoord
Gekozen oplossing
It's always risky to replace a battery without removing the screen. The flex cables that connect the screen to the board are very thin and can tear very easily. Take a closer look at the flexes, better yet under magnification. If you see even the tiniest tear, that may be causing the problem. The other thing to look at are the tiny components near the battery connector. Sometimes one or more of them can get dislodged and cause issues.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Pazmivaniye zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 9
Altijd: 123
