Ga door naar hoofdinhoud
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 Vragen Bekijk alle
Crank but don't start
I have a 2004 Pontiac Grand AM that cranks but does not start. We have replaced the fuel filter, fuel pump, fuel regulator, and fuel pump switch but it still does not start. Can you send me any more advise????????
Is dit een goede vraag?
Score 4
3 opmerkingen:
Please help ???????
door
After everything I had told you I was going to replace the crankshaft angle sensor and disconnected the negative on the battery after some delays I connected the battery back up and just out of curiosity tried to start the car and of all things the car started. Can you give me a opinion on why the car started.
door
That worked for me! Just disconnected the negative on the battery for a little while and reconnected it. Thanks! 2005 Grand Am
door
Voeg een opmerking toe
2 Antwoorden
Get your car scanned for codes first off. Always do that before replacing anything.
I'd bet though it is probably your crank angle sensor, but get it scanned first.
Was dit antwoord nuttig?
u must check engines before start ur car thats very imporant ur car before on road grab some sensor battery and check on battery on your car maybe is low or high and also dont forget about the oli its may low oil if oil is empty the car won’t started
Voeg je antwoord toe
Jimmy Samora zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 60
Altijd: 4,655
