NOT BLOWN FUSE: DS won’t charge bot DOES turn on
I fixed a blown F2 fuse yesterday and put it all back together and turned it on. I played from green to red and went to charge it and the orange light didn’t come on. I switched the charger, tried new batteries, nothing worked. Is it a problem with the power socket and what may have because this?
Is dit een goede vraag?
2 opmerkingen:
Hi @mar1nara ,
Do you know why the fuse blew?
If not then the fuse must have blown for a reason.
Something else may have failed which has caused the fuse to blow.
Perhaps in the charging circuit.
Without a schematic, unless it is an obvious component failure it may be difficult to find
door
I was converting it to a bottom screen only game boy macro, and I made the solder connection and that's when it blew. I had done it before, so I just fixed the fuse. I assumed it had something to do with my original soldering.
door
Voeg een opmerking toe
