Unibody MacBook Pro models with 13" displays produced from 2009-2012.
4179 Vragen Bekijk alle
Dull display on MacBook Pro a1278
Hi frnds
Got a MacBook pro a1278 I'm getting very feable /dull display on the screen
Actually it's intermittent once in a while it gives bright display , wanted to access to displsy cable tried opening from screen end damged front glass however I'll replace it once I'm.able to fix this issue
I got 3.3v on screen fuse, 12.5 on pin3-4 LED BKLIGHT CONNECTOR of screen(b133ee7 v2) I'm not able to figure out pwm enable & brightness control signal(unlike regular led screens) pins from motherboard or screen.end
Any help would be greatly appreciated
Rgds
Veekay
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
Pls any help would be greatly appreciated, rgds
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
Doorblader onze winkel
1 Antwoord
Gekozen oplossing
hi
sry frnds before anybody was interested in answering my question and help me fix
i figured it out the problem,
i suppose nobody wanted to share the trade secret haha
however i learnt it hard way and indeed costed me cost to the front glass which i tried to remove n broke as
i wanted to chk whether cable and screen were ok
coming to solution i found out that IC location u9701 which is LP8550 is a led driver unlike our regular PC screen where backlight works using 19v / backlight enable & backlight PWM for brightness
this particular mac uses +Ve / backlight PWM sync and 6 Return signals for backlight and brightness which is driven by LP8550 connected via serial resistors
i did a flux and reheat of the IC now works perfectly hope this feedback helps somebody someday
great day
VeeKay
Was dit antwoord nuttig?
Voeg je antwoord toe
Vasanth Kumar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 87
