Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
1124 Vragen Bekijk alle
Back Camera + Flashlight don´t work
Hello,
i have bought an Iphone 7 128 gb black where the seller says the back Camera is not working. So when i get the Iphone i checked all and all worked, only the back Camera and the flashlight for it don´t work. (Face time Camera works well)
I replaced the Camera with a working camera from another iphone to test it and have also the same problem. I take the motherboard also into another iphone to test if there is something wrong with the flexcable on the back, but nothing changed.
So is there a chip or something else who turns the light and camera on?
kindly regards from austria.
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
There is a chip on the motherboard that controlls the camera and flash. you will have to replace that chip to get the camera working, it is a very difficult process with high risk for first timers.
door
Hello, do you have a pic where i find this controller? regards
door
The camera and flash uses different chips,DA3 chip controls the flash while SN61280D controls the Camera. It's a 16 pins connector chip.
door
Een opmerking toevoegen
MacBook-reparatiesets voor batterijen
Vanaf $69.99
Buy Now
Vanaf $69.99
Buy Now
1 Antwoord
Gekozen oplossing
There is some circuitry responsible for powering the back camera and flash, this may be what's at fault here. I'm not clear on which motherboard you tried in which phone (lost in the translation ;>). Have you tried a known working logic board in the phone that has the flash and camera issue? If you have and the problem is still there, then your flash flexand camera may be damaged. If the replacement logic board works then your problem is on the original logic board and this will require a micro-soldering repair.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Josef zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 31
Afgelopen 7 Dagen: 143
Afgelopen 30 Dagen: 619
Altijd: 12,714
