Ga door naar hoofdinhoud
The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3949 Vragen Bekijk alle
iPhone 5s No Service/Line Searching iTunes ERROR -1
Hye I got n IPhone 5s sent in to me for repair. The customer claim that his IPhone having a No Service issue, and after restore iTunes got an error -1.
So my question is should I reball the BB CPU first ? After reball, what should I do if the problem not solved ? Cuz I read some thread on the internet saying that error -1 is not only because of BB CPU, some of them said its because of BB PMIC. How should I know which one is the right solution ??
Is dit een goede vraag?
Score 1
Commentaar:
do you get the imei when you dial *#06#
by
How can I get the imei number if the phone are stuck in itunes logo
by
it doesnt say in your question that its stuck on connect to itunes, try using 3utools to kick it off recovery or if that doesnt work try flashing the ipsw
by
lol. this is not a software issue, this is hardware bro. im pretty sure its hardware
by
If it's stuck in a iTunes recovery logo loop at least try to exit recovery mode via 3uTools.
It probably can still boot up if it didn't start flashing the firmware on there yet.
Then you can check what he said in the comments.
by
Voeg een opmerking toe
Android Fix Kits
Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
Nu winkelen
Android Fix Kits
Nu winkelen
1 Antwoord
Error -1 may be caused by connection problem, network connection or hardware issue.
About hardware problem, probably check the baseband.
Was dit antwoord nuttig?
Voeg je antwoord toe
Azim WHITE zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 528
