Ga door naar hoofdinhoud
HP released this ergonomic laptop (model number 15-au123cl) in October 2016. It features Windows 10 and a touch screen.
14 Vragen Bekijk alle
laptop battery doesn't reach 100% and laptop power off at 70%
i have hp pavilion 17t-ab000 CTO 17.3" laptop the battery doesn't fully charged and stop charging at 92% or 95% , then when i run my laptop at battery it powers off when battery shows as 70% charging within 20 minutes of web browsing should i replace that battery ? or there another solution
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If the laptop charger is correct, it's probably a problem with the battery. How old is your battery?
Was dit antwoord nuttig?
1 Opmerking:
As the seller said less than a month and i just installed new copy of windows then i detect that problem , before that i used it always plugged in
door
Voeg je antwoord toe
Moha Dabas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 327
